hey guys im baffled as to why my low oil pressure keeps coming on. did a oil change. has about 5 1/2 qts of oil due to high cap oil filter and when im rolling to a stop, i get a low oil pressure light coming on. i also have an aftermarket oil pressure gauge and it shows the same thing, it plummets close to 0 and sometimes justs reads 0. A few seconds later, it bumps right back up to 15 psi. what do you all think? need new oil pump or clogged oil galleys? the block was rebuilt about 5 years ago or so.
low oil pressure
valve train noise has been going on for almost 2 years since i got the top end redone ( refreshed and ported heads). While cold the block is at 60 psi and when warm ranges from 10 - 30 psi in idle and while driving 35- 60 psi depending on how warm it is. I also forgot to mention i hear a clunking noise while decelerating from the engine bay. new motor mounts so maybe the oil pump might be loose?Last edited by dan; 05-17-2017, 11:53 AM.
Sounds like the top end wasn't done right and needs to be done again, noise is no bueno. You could try replacing the pump but being that it's been driven with 0 psi and noisy I'm willing to bet it's rebuild time and that if you were to dissect the oil filter you'd find metal shavings.1985 LTD Crown Victoria - SOLD
Cut off wheel or hacksaw should do, right at the seam. Pull the filter media out and then open it up to see what's in it. Post pics. If there's metal in it you'd see it right away in good light, would glimmer like metallic paint.1985 LTD Crown Victoria - SOLD
Looks like a '90 or '91 if I'm not mistaken. How many miles on the bottom end? Also, what weight and type of oil are you running?Vic
Sounds like bad bottom end bearings. The pressure when cold, no pressure at hot idle is exactly what mine did when I got coolant in the pan and didn't change it before driving.
Vague possibility the pump is failing, but honestly I have never actually seen a V8 with low oil pressure that had a worn out oil pump. Its two gears that spin against one another inside a housing. Unless you run sand through it, there just isn't much to wear out.86 Lincoln Town Car (Galactica).
https://youtu.be/jDcPCQuMiro took this video right now after dropping my girl off at work
Sent from my Z956 using Tapatalk
At a highway speed cruise in OD, do you notice if the oil pressure changes with engine load vs coasting at the same speed?1990 Country Squire - under restoration
Originally posted by gadget73 View Post...Vague possibility the pump is failing, but honestly I have never actually seen a V8 with low oil pressure that had a worn out oil pump. Its two gears that spin against one another inside a housing. Unless you run sand through it, there just isn't much to wear out.
Originally posted by dan View Post10w-30 and odometer doesn't work so not sure on exact miles. And the sound has been going on for almost 2 years, I'd assume if it was bearings, the block would be toast by now unless I got lucky and have a magic block? Lol
Sent from my Z956 using Tapatalk1985 LTD Crown Victoria - SOLD
