Car has too much charge. Guage is up to the top and it's beeping. Charge goes up when on the gas. Charge goes down when you put it in gear and hold the brake. Lights dim as the charge goes down.
'87 Cougar - charging issues (EFI 302)
You mean it's charging more than 12-13 volts? If it is, the voltage regulator is blown. Internally regulated- time to swap.
If it's charging too many amps, then you're a moron, because there's no such thing!! :rock:2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Originally posted by Grand_Marquis_GTReplace the voltage regulator.
NOW.86 Lincoln Town Car (Galactica).
EFI 302s have an internal regulator- gotta swap the whole alternator.
Not like your 351, GMGT, which should be externally regulated.
But let me emphasize it, again...
NOW!!2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
put a voltmater on the battery with the engine running.........shouldnt be over 15.5v might just be that goofy sport instument cluster
You ask how to loosen the idler? Just get a long 1/2" breaker bar, put it on the idler (I don't remember if you need a socket too, or there was a square hole directly for the ratchet to go in), and pull towards the passanger side so that the pulley lifts up from the belt. When you release the idler it will go downwards a little more than its "belted" postion, it shouldn't spin around, but just to be on the safe side release it slowly and carefully.
the tensioner is spring loaded, put a wrench or a socket on the bolt head at the tensioner pulley 17 or 18 mm me thinks........have you checked the voltage running?
Just a standard mention, now is a good time for that 130 amp alternator upgrade
And not *all* EFI 302 are internally regulated. Mark VII had an externally regulated 100 amp alternator, and the Towncar (and probably other panthers) had an optional 100 amp alternator with an external regulator. Probably the same alt/reg as a Mark VII.86 Lincoln Town Car (Galactica).
Originally posted by gadget73Just a standard mention, now is a good time for that 130 amp alternator upgrade
Have your alternator tested before buying a new one, like Scott said.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
