I have had the engine block back from the machine shop for the last 3 weeks. Tomorrow I am starting to take measurements to make sure everything is within spec. What is a good cleaner to clean the crank, block, and pistons? I was thinking brake parts cleaner but I think it may rust with that. Any suggestions?
Engine cleaning solvents
1992 Mercury Grand Marquis.
Upgrades: Big Brake Upgrade, digital dash, Custom ignition Switch system, sequential tail lights, Teflon Fuel lines, LED interior lights, rear end rebuild with limited slip.
Future upgrades: 5.0 swap, 4r70w swap, aluminum driveshaft.
sigpicTags: None
acetone does a nice job to remove all oil. It will rust if you leave it dry though. Measure, then re-oil to keep it from rusting. Pistons are aluminum, they won't rust.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postacetone does a nice job to remove all oil. It will rust if you leave it dry though. Measure, then re-oil to keep it from rusting. Pistons are aluminum, they won't rust.1992 Mercury Grand Marquis.
Originally posted by gadget73 View Post..Pistons are aluminum, they won't rust.1985 LTD Crown Victoria - SOLD
If you find orange iron oxide on aluminum, you've got deeper problems. Yes, it does oxidize but it doesn't turn rusty orange like an iron block will.
How long it takes depends on humidity. The wetter it is, the faster it'll happen. I wouldn't leave it more than a few hours though. Get your measurements and oil it again.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostIf you find orange iron oxide on aluminum, you've got deeper problems. Yes, it does oxidize but it doesn't turn rusty orange like an iron block will.
How long it takes depends on humidity. The wetter it is, the faster it'll happen. I wouldn't leave it more than a few hours though. Get your measurements and oil it again.1992 Mercury Grand Marquis.
Originally posted by DerekTheGreat View PostActually, they do rust. That's why bare aluminum stuff usually comes heavily oiled. Once the oil is removed they rust/oxidize almost immediately, just the naked eye can't see it. Probably doesn't matter with engines but it sure does in the paint/pretreatment business.1992 Mercury Grand Marquis.
Wouldn't gas leave a residue?1992 Mercury Grand Marquis.
Originally posted by pivichot View PostI though they would corrode? Either way I have applied a coat of pb blaster to them once a week.1985 LTD Crown Victoria - SOLD
