Hey All,
My friend has an '83 CV with CFI. Right now, it only starts if you spray starting fluid down the throttle body. Once it's running, it will stay running and will continue to run fine. It won't cold start, or even start when hot.
We checked the fuel pressure and it looks to be right at 39PSI and doesn't drop when the engine is off. Shop manual says that's the right value. Also, the fuel pressure regulator on the top of the CFI unit has also been replaced and is brand new.
Checked the timing with a timing light. Timing looks to be fine and doesn't wonder all over the place.
Injectors spray fuel when the car is running, but they don't spray anything when the car is cranking.
Connector to the injector has seen better days but I'm not sure if that's it as it runs fine once the car is started.
Any ideas where to look? I know CFI is already run on magic and hope when everything is working properly.
We have the 83 Shop manuals for the car, but I can't seem to find any decent information in them surprisingly. I was hoping for a CFI troubleshooting section or at least a wiring diagram for the injectors... no luck so far.
I also just wanted to add, the car used to run fine. This issue just started out of no where. (No parts changed before it starting happening).
Thanks in advance!
Thanks in advance!
