So I've been talking shit for a while about all the crap I was going to put on the boat. Well it's all on now and....the result is, uh, interesting?
Here's the loadout: Edelbrock Performer 5.0 heads(CARB legal for the record). Typhoon (edelbrock knock-off) intake manifold upper and lower(reversible!). 1.7 rockers. 65mm lightning TB and egr spacer. C&L 73mm MAF(24lb sampling tube) FMS 24lb injectors(flowed), new IAT sensor, new ect sensor, new plugs, etc.
Findings:
The initial tune had a ton of advance which caused severe pinging(smaller chambers and shitty gas didn't help). Backed timing off a bit. Put in octane boost and refilled with premium. No more ping.
Car is a TURD down low. 3.08 gears exacerbate this situation but it is a shit getting off the line.
Once it starts pulling, the tranny decides it's time to shift. TV is normal but where this thing now makes power is where stock AOD says "upshift"!
Need to investigate possible TPS issue but also think it's way too much fuel with the 24lb injectors. Considering throwing 19lbers in there with the same sampling tube to lean it out a bit and see if that helps.
Manually shifting, wind up 1st a bit then lay into it, goddamn cars goes almost 60mph in 1st! Pulls like a fucking freight train between 1/4 and 3/4 throttle. WOT=bogging and unhappy feeling. WTF? Maybe too much fuel, see above.
So what say the panther gods. Right now, i'm sure I need to replace the timing set as it's probably original and might be fucking with things a bit, need to check TPS again, haven't ACTUALLY put a timing light on it, just backed it off a hair by eyeball. Overall though, seems like something is WRONG. Car runs fine, even with the AC on but I feel like the trans is really holding a lot of shit back, especially since I have lame gears and a stock converter. 3.73s and a stall would wake shit up, but it just doesn't hold the gears long enough to make use of the powerband. Would a shift-kit solve this or do I need to go full-retard and get a valve body? The more I look at this the more I wish i'd just held out and did the whole goddamn drivetrain at once! The shop is now pushing me on a coyote swap. Rich for my blood but by the time this mess is solved, i'd probably be happier.
Findings:
