The only different thing about he '91 filter I recall is the way it's attached to the frame rail - it uses a steel bracket and a big worm-drive clamp (like a hose clamp really), as opposed to many of the earlier models where the filter sits in a plastic cup with hole on the bottom (for the inlet fuel line IIRC) which bolts to the face of a steel bracket that also has a hole in the middle (for the outlet fuel line). I like the hose-clamp setup better - it has no plastic parts to crack and semi-threaded screw holes to strip out, and once you pop the clamp off you can now tilt the filter any way you want it to easily direct the draining gasoline wherever you want it.
Orange fuel filter retaining clip, can't find a replacement.
Oh yeah that's right, I forgot all about that different mounting since I haven't been under my '89 in a few years. I only remembered that the fuel filter and lines were the same.Vic
That gives with my memory as well, fuel line couplers are the same as the old stuff. Now if you move up to the fuel tank area, things are different there - you get front-load sender/pump setup (still lockring-retained tho, no 6 bolts like the later ones) with braided stainless lines and the type of couplers that require a special tool to disconnect them (or a piece of plastic air line if you're creative with it).The ones who accomplish true greatness, are the foolish who keep pressing onward.
Can you replace the pump assembly on a 91 without dropping the tank?
I threw the old one away but here's the best representation I could find of the old:
And the new:
Upon looking a little closer, the line might have been replaced at some time when I previously thought it was stock. There were zip ties holding it along the frame etc.
Sent from my XT830C using Tapatalk
ungodly clean looking under there.~David~
The fuel filter bracket on my blue '91 was in the same condition so I grabbed another one from the JY, cleaned it, painted it and slapped it on.
I think you can change the fuel pump/sending unit assembly without dropping the tank but dad and I dropped the tank anyway when the in tank hose split on the blue '91.Vic
Just make sure the fuel level is down pretty far before you attempt it, otherwise you're getting a gasoline shower.86 Lincoln Town Car (Galactica).
Oh boy that sounds like a real good time lol. I plan on taking it out to see if it's the stock one. I may replace it for preventative maintenance. I always have the worst luck getting caught with a dead pump...usually from previous owners using the cheapest local replacements they can find. Any thoughts on the Carter pump assembly for these cars? I've used them on others with excellent results.
Carter is OEM for many vehicles, draw your own conclusions. Airtex is to be avoided if the particular unit is not made in the USA, check the box for country of origin. Bosch is also OEM, reliable and stuff.
Don't mess with the tank unless you're replacing it. If you need to replace the straps do them one at a time. Fuel pump comes out the front on that model year, have fun with the lockring if it's rusty - get a new lockring and o-ring seal from the parts store. Since old fuel pump is still running just use it to empty the tank - disconnect the engine-side line from the fuel filter, replace it with a regular hose and lead end of said hose into a fuel jug, then juts replace the fuel pump relay under the hood with a piece of 12-awg wire with spade connectors on each and and go have a drink or snack while the pump is doing the dirty work for you.The ones who accomplish true greatness, are the foolish who keep pressing onward.
