Sedan fuel tank in a wagon?
    has anyone installed a sedan tank in a wagon by any chance?
    looking into a build on a colony park that requires a returnless fuel system. Simplest solution would be to get a 90+ fuel tank and use a 04+ pump and hanger with the single line.
    i figure we might have to dimple the back side of the tank to make it fit.
    Can you just cork off the return line, or swap the pump hanger assembly?
      I tried, there isn't enough clearance for the pump and level sender once the rear of the tank is "clearanced" for the bump.
      If you got rid of the in floor seat in the back of the wagon, it would work but I think that's the only way.
        To build off of this, why not chop off and braze/weld the hole shut?
          Having the return port inop is not the issue. Having the correct pump on the other side of it, however, is - the returnless setup uses the PCM for modulating pump speed and pressure, reads off a pressure switch on the fuel rail. Basically another of Ford's "better" ideas, let's save a bit of money by nixing the extra line and instead over-complicate the fuck outta everything else.
          From pressure consistency point the easiest solution is dropping a bigass pump in the tank and then running a return-style FPR somewhere between it and the fuel rail. Heck even a Vette filter/regulator would work pretty sweet especially since it's an OEM solution and thus proven reliable (unlike the aftermarket stuff, unless we're talking big-bucks stuff like Aeromotive and such). But again the issue is the damn PCM will want to see a pressure response from the pump via the fuel rail sensor, and a self-contained constant-pressure setup ain't gonna give it that.
          I do like the idea of losing the stupid jump seats and reshaping the trunk to fit a normal sedan tank, then the bitch can run a late-model sedan tank with the returnless system and be all good-like.
            I still don't see the problem. Can you fit the later style pump into the old hanger and just connect up one line? Or can you fit the later hanger into the old tank, and still just use one line?
              Later hanger into old tank will be a tricky one - the new-style uses 6 bolts to attach to the tank and the hole is on the side facing the axle, the old-style setup uses a lockring and IIRC the thing lives on the rear wall of the tank facing the trunk area. Tho I'd imagine punching a bigass hole on the front wall and finding a way to attach the bolts to the tank won't be all that hard, already got an idea actually, gonna check how feasible it is tomorrow.
              New pump in old hanger, maybe, depends on how many wires the variable pressure junk runs thru the sender bulkhead. I think I saw 3 in a picture somewhere, the old stuff only runs two wires IIRC.
                Newer uses 4 wires I believe, 2 for the pump and 2 for the level sender. Older has pump power on back side and 2 wires for the level sender on the front side. The level sender won't clear a center mounted pump, my pump is in the stock location all the way on the drivers side(sucks taking lefts when the tank is a bit low).
                  Also, the stock box level sender has very different resistance value compared to aero or whale, I built one using a different sender then found it would not clear the bump so I have an assembly sitting in a box ready to go.
                    Sending unit from/for 1989 Town Car should use the same resistance range as '90+ panthers but it fits '89 and older panther fuel tanks and the electrical connector is identical to '89 and older panthers.
                    Vic
                      Well, if the later one uses 2 for the pump and 2 for the float, then just using the existing wagon float plus the new pump on the old hanger would let that work. No need to change the level sender or anything like that.
                        I may be wrong on the wiring, I had a return style setup so it may be different with returless...I forgot about the idea to go returnless.
                          Motorshaft image of a pump assembly for a 2011 Townie looks to be 4 wire, 2 for pump and 2 for float.
                            resurrecting this one...I'm looking to put a 90+ tank in my 84 wagon - I really want the easier pump access for a project I'm working on...is this possible? Do the 90+ wagon tanks have the pump on the axle side or is it on the "trunk" side like the earlier ones? I know my 90 TownCar had the pump on the axle side...
                            thanks!
                            1984 Mercury Colony Park Wagon - 393 Dart block LS 91mm turbo with 4L80E and 9" 6.24@115 in the 1/8 mile (9's in the 1/4), 4650lbs w driver, AC, Drag n Drive rig 1300hp
                            1988 Lincoln Town Car - stock for now
                              thanks!
                              Wagons stayed old school. Pump on top. Separate fuel level sender on front side.
