spout
    spout
    dudes i adjusted the timing in 91 crown vic and put the spout on the washer reservoir, drove off for test drive and
    you can guess the rest. a few years ago no problem, now none of the yards near me have any boxes. they do have plenty
    of f150s will this work?
    1989 crown Vic daily driver 165k and counting!
    1987 MGM 49xxx mi awaiting light resto
    Yep, same part. Its just a jumper, you can use a paperclip and some tape if you absolutely have to.
      i had no idea, thanks. i just put new top end gasket kit on and want to at least get a whiff of the fruit.
        On one of my old drag cars I drilled a hole in the jumper & attached it so that I would not lose it in the pits again.
          leashed with a piece of wire or something?
            Yeah sounds like that was the idea.
