![Frown](https://www.grandmarq.net/vb/core/images/smilies/frown.gif)
Smog pump (?) Locked up.
run the belt over the pulley instead of under the pulley. Works fine.
Anyone know the best way to get the belt on? Can't get it over the a/c clutch
Sent from my SPH-L720 using Tapatalk2010 Toyota Camry "Traveller II "
54,xxx miles. New daily driver
2001 Lincoln Town Car Signature "Leroy"
rear cats deleted, 2" h pipe, dual 8" cherry bomb glasspacks
114k miles. Sold to my coworker.
1998 Toyota Camry "Traveller"
Dead and sold.
Did you loosen the tensioner and swing it out of the way first? The bolt comes in from the back side.86 Lincoln Town Car (Galactica).
I loosened the bolt on the far left of the tensioner and it won't budge...is there another one I'm missing?
Dead and sold.
yes... reach around the BACK of the mounting plate. There's a bolt on the BACK. The bolt you loosened was the pivot bolt, not the bolt that actually holds the thing in place. 14mm IIRC too.
Thanks! I actually found it earlier. I actually had to loosen the bolt behind the tensioner AND remove the pivot bolt to get the belt to go on, but it worked and once it went on it had alot more slack. I was surprised I was able to adjust that and the alternator the first time without it squeeling. Never been able to do that before. But anyhow, thanks for the help yall! It's good to know that even though I don't have a panther anymore, I can still get help when I'm working on my brother's.
Dead and sold.
Ditch the smoooooog
1985 LTD Crown Vic, factory hard top, 302 soon to be gt40p headed (lightly ported & blended), summit brand stealth (port matched), stock cam, summit annular 600cfm VS, dual exhaust, 3.55 LSD, AOD, electric fan swap, tan interior.
