I recently had to change the water pump and timing chain and cover because a water jacket in the timing chain cover was cracked and leaking coolant. I figured I might as well change the timing chain while I was in there as the original had a significant amount of slack. The car has always had a minor oil leak, maybe about a half quart every month. Ever since I put everything back together I started seeing the oil leak getting much worse. I couldn't find out where it was coming from until today. There is a hole on the side of the timing chain cover that pours oil out when the ac is on, it does not come out nearly as much if at all with the ac off. I was wondering if anyone knew what this hole is for. I took a picture from where it's leaking on the car (sorry for the crappy angle) and also downloaded a picture of the timing chain cover to pinpoint exactly where I'm looking.
There are 3 holes in question that currently have nothing attached or bolted to and I was wondering if anyone knew if there should be a bolt or something else in there. The red arrow in the picture points to the hole that is leaking, but unfortunately cannot be seen in that photo of the timing chain cover. In the other picture from my engine bay, the red highlighted hole is the one that is leaking or more like hemorrhaging oil. The other 2 yellow highlighted holes also have nothing in them but it looks like something is definitely missing there as the smaller of the 2 yellow holes is threaded. Any help would be greatly appreciated. If there's anything that I left out please feel free to ask me any questions and I will answer to the best of my abilities. Thanks again.
