What kinda motor is it, and how much shipping will it cost me to have you send it here?
Insane Idea - 460 CID (Now 351w options)
Clearance for the rotating assembly. the rods on that stroker crank will need some metal removed from the block to clear when spinning at temp and RPM range. It's a typical step in stroked engines.
It requires time consuming dremel type work to hog out the locations needed for crank clearance.
Mike, if your half as good with mechanics as with puns....look out!
1979 Marquis creamy goodness
DuceAnAHalf (Ryan) has a 351w (probably 358ci) in his vic. If you make it over to Scottfest, I can bring it with me from Tampa and meet you there for pickup
If you build a 408w, there's no clearancing needed. IMO, its not worth your trouble for the extra few ci to do a 418w, and a stroker is really a stretch for your plans anyways.
'80 Town Coupé
