Hello everybody,
I'm posting this on behalf of Ashley; Yesterday I was able to have her car scanned as the CEL popped on while driving home. Code PO304: Cylinder 4 misfire detected. Scanner detected it twice. The CEL is starting to pop on more often and sometimes when it does the car has a chug under slight loads (makes sense if only 7/8 cylinders are firing) and in neutral or park the idle is higher than usual. Car is also hard to start, has been since she bought it. Sometimes it fires right up, other times you gotta crank it for up to 5 seconds but once it fires it runs great and smooth, up until the CEL pops on.
What we've done to it so far is new plugs, wires, cap & we swapped out the TFI module with a knock-off brand found in a boneyard. Car started up better & consistently but after a week or so it's like it went back to it's old ways. Hell, that could be why the car is worse now. So we're thinking we should swap that out again with a new Motorcraft unit. What else should we look into? What could be causing the plug to foul out or not fire???
Best regards!
Best regards!
