Vibration at certain MPH
    So it's been doing this for a little while and I can't figure out what it is. When going between 50 and 60mph the car will have a vibration that feels like it's coming from the front end but the front end is all new.. Steering wheel has little to no vibration.. I'm thinking unbalanced tire or maybe driveshaft? The wheel bearings are new too and I have checked them and they're fine. Any ideas?
    so the steering wheel is not vibrating. Is the seat vibrating? the rear end?
    -1973 Volkswagen Bus Westy
    -1986 Honda Magna 700cc
    -2011 Subaru Outback
      Yea the whole car vibrates but not the steering wheel
        then it's probably the rear:
        Check:
        Driveshaft? Is it balanced? Is it seized?
        Tranny motor mount ?
        Wheels balanced?
        Doe sit happen all the time, ior is the vibration intermittent?
          +1 trans mount. if it's cratered, it'll press on the cross member at some point.
            on a side note, is it easy to replace (tranny mount) and how many are there?
              I believe there's only one on the cross member. Should be as simple as jacking the trans to support it and then unbolting the old mount and bolting the new mount in. (Granted it's not become one with the cross member lol)
              I think Energy Suspension makes a poly mount that works for our cars but I don't remember the part number...
                i guess you can check to see if the mount is bad by stick a pry bar in there and try to move the tranny.
                I am just wondering about how it would cause the vibrating
                I am in the same boat as the OP
                  I once bought a used Taurus that had a wheel balance issue. It only showed up as a vibration at highway speed. I would think a balance issue would have a distinguishable kind of vibration, but I have no way of describing what that would be. I guess you'd just have to imagine what kind of effect you'd get from unbalanced wheels and compare that to what you're experiencing. If the tranny mount doesn't show anything obvious, and if your wheels haven't been balanced in awhile, the balancing is probably cheap enough to try just to see what happens.
                    true, wheel blancing isn't a big deal.
                    chitownvic, does it happen (the vibration) when you give it little throttle, or is it independent of that
                      The drive shaft is original to the car and I'm pretty sure balanced but in need of U Joints.. I put the trans in the car and know the trans mount is fine.. The vibration only happens at highway speeds around the high 40's to 60.. Anything slower or faster is smooth sailing and acceleration dosent matter. My money is on the wheels because they are old rubber and off the black town car and I truly have no idea how old they are I'm going to replace then soon and hope that fixes the problem
                        Try swapping the wheels to the back 1 at a time, see if it feels different..
                          I have had 2 things in the past that made the same vibration. First was a driveshaft U joint but you should hear a clunk when shifting from reverse to drive. The second was water in the tires from crappy air pumps on a slow leak but that got worse over time.
                          13 F-150 XLT 6.2 l
                            No clunk but I know they're probably original to the car.. That's crazy about the tires I can totally see that happening because people rarely drain their compressors or have a dryer on them
                              Is it fine when the car s cold, but started happening once it warms up?
