+1 never had a problem with cruise... just the AC vacuum check valve checking out.
A simple frozen Smog Pump question...
Smog pumps make great additions to any scrap pile.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
So if the Smog pump is taken out, then it affects the A/C system?"To Find yourself, you must first lose yourself"
-1973 Volkswagen Bus Westy
-1986 Honda Magna 700cc
-2011 Subaru Outback
How would you cap off the holes that would be behind the heads?
Originally posted by johnunit View PostThat feeds two lines in the back of the heads. It pumps air into the heads right after the exhaust valves in certain situations, as opposed to into the cats. My understanding is air is pumped directly to the cats to help warm them up, while it's pumped to the back of the heads to keep them from overheating while still injecting oxygen to burn any raw fuel that sneaks through.
Here is a picture of roughly what's back there, though in your car most of that valve nonsense at the top left is on the fender, not behind the engine. Circled in blue is where it connects to the heads.
Porschpow, some screw in 5/8 x 11 bolts after cleaning the head threads. Others cut off the pipes, seal the air passages on the remaining end sections (blue circles), and reattach them.1987 Grand Marquis LS two door, trying to get to the 60,000 mile mark.
Originally posted by porschpow View PostSo if the Smog pump is taken out, then it affects the A/C system?86 Lincoln Town Car (Galactica).
removal of hose and disk
gadget73, if I disconnect the hose down to the air pump, and the round disk in the center of the picture, and plug the hose continuing under the intake, then my worst symptom may be reduced vacuum to the cruise control. Is that correct? The round disk has "vac" on it, and an arrow pointing outward, so I can't figure out which direction it restricts. It's black on the air pump side and white on the continuing hose side.1987 Grand Marquis LS two door, trying to get to the 60,000 mile mark.
that hose under the intake is supposed to go to the evap canister under the battery I think. That you'll want to leave alone. The hose from the smog pump actually goes around the back of the engine to the cruise control T check valve. You can pull that thing all out and put a plug on the T where it was connected. This is of course if I'm remembering correctly. It has been a couple of years since I pulled that crap off of my car.
