Hey guys,
Researched some other threads and here is what I "know":
- My car has a separate fuel pump and sending unit
- The Mustang upgrade pumps only work with a "spacer" (radiator hose can be used but I question whether fuel would deteriorate it)
- There does not appear to be a good new sending unit replacement for my car
Issues:
- Partial fuel pump failure. I think one of the vanes is sticking. Only manages 20-23 PSI and it bleeds down to 0 (engine off) in less than 30 seconds. Already replaced FPR. Also the low fuel light is on however there are less than 3 gallons in the car so I am not absolutely sure the sending unit is bad. Also the fuel gauge appears to be working (I don't know if the light is integral to the sender - that is, either both work or neither work).
My car is currently stock. Over the winter I plan on taking it to at least base H.O. level. Within a year or two I plan on a turbo setup, or a used supercharger setup in the meantime. I'd like the fuel pump I install to at least be able to handle H.O. / H.O. with a few additional mods. I'd really like if the upgrade I do now is sufficient for the future setup but that is not a priority.
Any ideas? Would like to order a pump this weekend.
Issues:
