Did the new distributor include all new electronic components or did you transfer anything from the old unit?
88 Colony Park Loss of Power
when this happened to me, it was the MAF. Not going to be your issue unless it was converted though.
Very weak fuel pump would do this too. Can you check fuel pressure? Worst case, a cheap tire pressure gauge will tell you but it kills the gauge. If its less than 30 psi with the engine running, no bueno. Should be 30-35 at idle and 40-45 at idle with the vacuum line unhooked.
Dead fuel pump relay might do it too though I wouldn't expect the car to start. They basically work or do not work, though they can go intermittant and spazz out randomly.86 Lincoln Town Car (Galactica).
Just because its not old doesn't mean it shouldn't be checked out. Could be the fuel hose in the tank came apart or something.86 Lincoln Town Car (Galactica).
also a plugged fuel filter can cause buggered running issues.
fuel could certainly be the problem. The "new" distributor, I guess you did not swap over the internal components.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
