Ford Racing Plug Wire Part Number.
    I was wanting verification of the part number for the Ford Racing Wires. I looked on here and could not find it. The part number for the wires I am showing is Ford Racing M-12259-M301 for the blue ones. Is this right?
    1990 Colony Park, with HO swap.
    Previously:
    1990 Lincoln Town Car Cartier.
    88 CVLX
    01 Marquis
    That's it, yeah.
    Be aware they'll only sorta fit into your old plug looms/separator if you have stock (8mm?) wires on now. They fit on the cap and plugs just fine though.
      Can always neatly zip tie the "boys", if necessary.
        Got ya. Do any of the aftermarket wire looms fit? the look to be a couple bucks online,
        Previously:
        88 CVLX
        01 Marquis
          Yea just make sure they fit 8mm
            I think that number is the black wires, M-12259-C301 is for the blue. That's the number I have used to order mine in the past.
              Awesome. Ordered.
              Previously:
              88 CVLX
              01 Marquis
                So I got the wires. They included two extra wires for the ones that go from the ignition module to the distributor. However, one is way to long and the other is about 3 inches too short. Any thoughts? I can get photos of them later.
                Previously:
                88 CVLX
                01 Marquis
                  Use the long one.
                    +1 use the long one.
                      Do you mean the spark plug wire from the coil to the dizzy???
                        yea
                        Even if the long one is 4-5 inches too long? is there a way to route it that keeps it out of the way?
                        Previously:
                        88 CVLX
                        01 Marquis
                          Should be able to tuck it somewhere behind the dizzy or thereabouts. Just be careful of heat sources.
                            Will do. Thanks.
                            Previously:
                            88 CVLX
                            01 Marquis
