how much did you notice your HO conversion
    i was wondering what you guys thought when you first hit the pedal after your HO conversion. I guess i just want to guage how much the car will be different with all those extra horses
    Well, it ran good. When I went to the track and ran a 15.45, I got the timeslip and said "HOLY SHIT" My best pre-HO was 16.03
      Mine is no rocketship, but its def got a lot more under the loud pedal than before, but we're also talking a whooped on 125k motor vs a fresh rebuild. You should notice it, but its not going to to be like getting into a GT500 either.
        my towncar is a rocket
          It definitely makes a difference. A set of gears will be a big help too. I almost think that was a bigger difference than the motor!
          FOR SALE: 89 Grand Marquis GS HO. Quarter mile = 15.8 @ 87mph -- pics http://public.fotki.com/vfr700f2/car...rcycl/mercury/
          Junkyard HO, MSD wires, stock Mustang headers, off-road H, Hemi Super Turbos. 3.55 trac loc, HO governor and servo in stock rebuilt AOD. 3-row rad, air pump delete, cop rear bar, wagon rear springs, 93 CV rear discs, 98-02 Grand Marquis wheels, Class 3 hitch, aluminum space-saver spare.
          Coming soon: 98-02 front brakes, cop springs, Monroe cop shocks, 96 Cobra wheels w/255/50/17. Better yet, need a nice wagon to put all that stuff in.
            well to update you guys on my current status, the lower intake is pulled and i found some clumps of oil under the pushrods, got the crank pulley off, but i need the right size socket to fit the crank bolt and i need a balancer puller. Removed the smog pump and blocked off the vacuum lines going to it, and thats about where i am. all is going well so far.
              take a shop vac and pick up all the clumps........dont want them clogging up the oil pump pickup
              the crank bolt is 15/16" you can get a puller from harbor freight tools pretty cheap
                Switching to my HO was a massive improvement.
                  I wouldn't know how much I'm going to like it... but I'm switching to a T5 at the same time, so the feeling will be exaggerated.
                  I can't sleep at night because I'm too excited about getting this done. I have a $500 shopping cart on Summit waiting for my paycheck Friday and I pick up the motor Saturday (paid for it today).
                  I actually passed on getting a MINT 1983 Mustang GT 5-speed for $1200 (considerably less than I'm spending on all this) because I want my wagon more than something that could easily be much faster.
                    good choice! mustangs are like assholes :asshat:
                      Right- everybody's got one... but not everybody keeps theirs clean.
                      ...and this one is CLEAN.
                        nice! needs 17" wheels and big brakes lol
                          Mine has crappy exhaust right now. I'm sure it will be better once thats taken care of. It certainly goes right now, but between the crap exhaust and the vacuum leaks making it run a little funny, I'm sure it isn't optimal. I already had decent gears (3.55 factory LSD) so my stock lopo was a bit perkier than most. That motor actually ran quite decent untill it lost oil pressure and started to knock. It ran strong right up till I parked it. If I had all this to do over again, I'd probably have done a gt40 motor but at the time I didn't know any better. I learned a lot doing the swap, and I've learned a lot more since then.
                            I had 17" Mustang GT wheels on it, but I got tired of them.
                            Those are police wheels in the picture. I have some cheap (free) 15x8 wheels with 4" backspacing for the next set of tires- Yokohama Avid S/T 295/50/15s in the back and 255/60/15s in the front.
                            While I'm burning those up, I'll be saving for a set of Cragar 16x10 (5" backspace) for the rear and 16x8 (4" backspace) for the front. Same tires up front, but 325s in the back.
                            Still gotta get this motor/transmission stuff lined up, though. It's very intimidating, considering I don't have anyone to help me out.
                              That's a nice wagon.
                              Nick
                              88 Colony Park LS
