:stupid:
I pulled my motor ......
HEEEEYYYY!!!!!
If your willing to do a cam swap, I will give you my HO CFI ECM for free if you find the cam.
Fo realPete ::::>>> resident LED addict and CFI defector LED bulb replacements
well the botom end of my motor is all junk... :cuss: crank thrust is .014 it should be less then .007. cam lobes are smoked. looks like im doing a complete rebuild.... now i need to pull money out of my ass to pay for parts i was not expecting. $530.00 in basic stock internals. I hot tanked the block today. tomarrow i will take all its measurments. I hope i dont need machine work :bs:
thats what im hopeing. its going to be bored .030 over. the block goes to the machine shop monday morning, i hope.. so i will need new pistons. and i'll be installing ho heads port and polishing them and the intake. and if money is there mabe headders
update
the engine has been bored .030 over, installed aluminum pistons, 86 H.O. heads decked .008 & ported and pollished, lunati cam and lifters, stock replacement crank, federal mugal bearings, new oil pump, timing chain & gears. and lots of paint....
She was installed today and runs great. i only ran it for about 20 minutes timed it and reved it to break in the cam. then i changed the oil and filter for the first time.Im going to try to put some miles on her before i run it on the dyno
:slug: :slug::slug: :slug:
:slug: :slug:
:slug: :slug: :slug::slug: :banana: :rock: :slug:
Nice work!!, congrats on a good runnin motor!
