Is there a difference between the two pulleys? I'm doing a 351 swap and need to know.
351 vs 302 Box Panther Crank pulleys.
87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
Mods to come: Big Brake/Poly Front Swap, PI Front Swaybar, Addco 650 Rear Swaybar, Boxed Upper Rear Control Arms, 351/Alum Heads, FRPP Valve Covers,Tags: None
There is a difference in offset between Mustang 302 and Crown Vic 351W crank pulleys. The 351 setup protrudes something like .420" further out from the front of the engine. I know that's not panther vs. panther but maybe it helps.
same pulley as far as I know. You do need the 351 balancer and flexplate though. They are not the same as 302 parts. Looks the same, but the balance is wrong and you'll shake things apart if you use the wrong ones.86 Lincoln Town Car (Galactica).
Okay guys. We'll see, but in my estimation they should be the same.87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
The balancer and flexplate are definitely not. They are for a 28 ounce imbalance, and 302's made after 1982 use a 50 ounce. Its the same as the early 302, but not whats in your car. Bolts up and looks basically the same, but its just not. The pulley itself is the same though.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostThe balancer and flexplate are definitely not. They are for a 28 ounce imbalance, and 302's made after 1982 use a 50 ounce. Its the same as the early 302, but not whats in your car. Bolts up and looks basically the same, but its just not. The pulley itself is the same though.
