Charging problem fixed .Now new problem 1991 GM
    Hello again,
    The problem with the battery light being always on and battery draining over night turned out to be in the main wiring harness and connectors on the alternator. That is now fixed.
    I took it to an electrical shop to fix. They reported the problems as the wiring harness was bad and the connectors to the alternator were bad also. Since this was a speedometer shop, I asked them to calibrate the speedometer. When I was going 40 I actually was going 60. I remembered I had the 140 speedometer on the shelf. I took it up to the shop and they replaced it too. That afternoon when I picked up the car, a rain storm had started. As I drove away from the garage, the car was running like shit. I drove one block and returned it . This was July 3rd. They pulled some codes and said the coolant sensor was bad, also said the electronic timing sensor / spout connector was bad too. After replacing the ECT the check engine light went off for the first time in a year. They now say the timing sensor is okay. I had replaced the ECT along with other sensors about 6-7 months ago. They did a smoke test and now they say a vacuum hose is off under the intake and smoke showed around the master cylinder.
    I attached a video of the car running before I dropped it off the first time. I think it was running fairly good.
    Now it runs like the timing is off, coughing and backfiring
    Could it be the vacuum hoses?
    Thank you again,
    Mike
    PS on the plus side the 140 speedometer looks great.
    90 Colony Park LS with GT 40 heads and intake. HO cam, 65 MM TB, 67 MM EGR spacer. Has a 75 MM Pro Flow mass air sensor. Borla XS mufflers. 3L55. Shift kit, 2000 stall Tq convertor...Bilstein shocks, front and rear sway bars.
    90 Colony Park LS 64,000 miles all original. 3L55 tow package....front and rear sway bars.
    91 Grand Marquis GS....HO motor..Bilstein shocks poly bushings and police swaybars. This one handles the best.
    70 Torino Squire with M code 351 Cleveland 3.00 has Magnaflow mufflers. Hidden headlights and power windows. All original
    yeah... check the hose to the MAP sensor and the other hoses on the vacuum tree back there to make sure they didn't knock something loose. I know I've done that without noticing before.
