Playing Whack-A-Mole wit the LTC
    OK SO I installed a new EGR valve position sensor and EVP (EGR Solenoid)
    Before I did this I cleared the code, Pulled the wire while key was on (but not running)
    It had 11 code then 34
    Now, after I changed the parts I have three codes
    94 Something to do with the air system
    74 Brake pedal depressed (don't remember pressing it)
    and 34 (came back)
    With the key on engine running these codes came up
    WITH THE KEY ON ENGINE OFF, only 34 comes on
    The valve TO the EGR was ok, When I pulled the vacuum direct to the EGR valve, car stumbled to a stall
    I pulled A vacuum to the Red and Green lines to the solenoid and they didn't hold the vacuum
    I didn't re-check the vacuum system with my pump since it started pouring
    But I am surprised now!!
    -1973 Volkswagen Bus Westy
    -1986 Honda Magna 700cc
    -2011 Subaru Outback
    it won't do anything if you pull vacuum on the red line. It connects to the intake on the other end. Basically you're just sucking on a straw thats open at one end.
    the green line must hold vacuum. If it doesn't, you'll get the code 34.
    74 is from not stepping on the brake pedal. Ignore this.
    94 is thermactor air injection. If you have the red line unhooked during the test, or if there is a leak in that line, it might cause this. All of that stuff runs on a common line from the engine. Without solid engine vacuum, none of the smog stuff works. I got rid of my plastic lines years ago. They were all falling apart, and it leaked at the connector. Rubber lines with colored zip ties to identify things works better for me.
      I might have to do that (replace the vacuum lines. So, in lieu of the plastic lines, what size rubber hoses should I get.
      I will investigate to see what is going on
      Just to make sure were on the same page, I put a vaccum on the red/green hoses going to the solenoid...not the Intake/ EGR valve
        correct, the green hose that goes from the solenoid to the EGR valve. It has to be connected to the EGR valve end.
        dont remember what size it is. Take a part to the store and match it. Use something that fits snugly so it won't fall off or leak.
          no no, what I am saying is I unhooked the green and red line (separately from the valve and intake respectively)
          After then I hook the vacuum pump to theopen end (Valve/intake side) and put a vacuum to the solenoid side and I had no vacuum, I did on the egr valve
            I've had the same problem with my car. I replaced all the vacuum lines and replaced the EVR. Still get he code. EGR tested okay and vacuum lines seemed to be working as they should. I bypassed the AIR stuff that the red line also supplies vacuum to.
            My fuel economy has been good and the car seems to run okay so I gave up on looking for now. I'm ganna follow this thread to see if maybe I missed something...
              and 34 (came back)
              I am confused... the EVP is the EGR valve position sensor, it is mounted directly on the EGR valve and has the green vacuum hose going to it.
              The EVR is the EGR valve vacuum regulator solenoid, which his mounted on the passenger inner fender. basically a black plastic solenoid with 2 vacuum hoses and a 2 wire electrical connection.
              Are these the parts you replaced?
              Code 94 is for the air injection system not working and is usually caused be a vacuum leak. Check the vacuum harness on the passenger side of the engine compartment for cracked vacuum line. also check vacuum connections at the diverter valve on the passenger side exhaust and under the AC compressor, on the back of the air pump.
                Yes, I did replace both of those.
                Where would the lines fail in the harness??
                Where do I find this diverter valve under the compressor
                  I couldn't find the diverter valve, but I changed the Egr valve (it hold vacuum), solenoid and the green and red hose holds a vacuum.
                  I cleared the codes and now with key on engine off , I got code 1 1, over and over. Which means everythign is ok
                  But when I do key on engine on, heres is where the weirdness happens:
                  It first blinks four times than engine idles higher, goes back down hen up again then down after a while.
                  It gives me the code 94 and 74 at least twice!
                  WHAT GIVES?!?!?!?!??!
                    94 is "Air Injection is inoperative" so perhaps the smog pump or one of it's "parts" (like a vacuum hose) is faulty. 74 will ask if you depressed the brake after the start of the test. Don't think you need to worry about that one. If you still have emissions testing you may have to deal with the "94" code.
                      so, the lines in the egr system, lines in the smog pump system and/or the smog pump egr itself is faulty. Is there a schematic of these systems????
                        Someone here probably has a ETVM schematic they can post or at least a link. Wouldn't hurt, if you are keeping the car, to get one (possibly from EBAY??).
                          I have an '89 EVTM that I can scan and send to you. Just let me know what pages you need.
                            Awesome! Just to troubleshoot the issue with dcode 94.
                            So EGR system and Smog system. Im new to all this, so I am probably not addressing this right. This is just so freaking ridiculous!
                              The plumbing diagram for all of that is on a sticker under the hood of the car.
