OK SO I installed a new EGR valve position sensor and EVP (EGR Solenoid)
Before I did this I cleared the code, Pulled the wire while key was on (but not running)
It had 11 code then 34
Now, after I changed the parts I have three codes
94 Something to do with the air system
74 Brake pedal depressed (don't remember pressing it)
and 34 (came back)
With the key on engine running these codes came up
WITH THE KEY ON ENGINE OFF, only 34 comes on
The valve TO the EGR was ok, When I pulled the vacuum direct to the EGR valve, car stumbled to a stall
I pulled A vacuum to the Red and Green lines to the solenoid and they didn't hold the vacuum
I didn't re-check the vacuum system with my pump since it started pouring
But I am surprised now!!
and 34 (came back)
