This may sound nuts, but................
Last week while on the lift I had the shop drain the Prestone from the radiator.........they did not want to pull the drain plug from the block as they feared it breaking.............anyway all the Prestone comes out..........and here is where I think I screwed myself.......the shop put back two gallons of anti-freeze, pre mixed..........so can I assume that two gallons of pre-mix is really only one gallon of full strength?.........and if so, I should have poured in two full un-diluted gallons, then add water to top off...........am I correct?
What should I do now, the radiator is full up.
