Could OIL PRESSURE light mean high pressure?
    I threw a quart of 15w40 in my engine which is leaking oil like a sieve. My intention was to thicken the oil slightly if possible. I noticed the oil pressure light going off yesterday. Could the "OIL PRESSURE" light on my digi dash be indicating HIGH PRESSURE? Or is it only a low pressure indicator?
    87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
    Mods to come: Big Brake/Poly Front Swap, PI Front Swaybar, Addco 650 Rear Swaybar, Boxed Upper Rear Control Arms, 351/Alum Heads, FRPP Valve Covers,
    It's a switch that turns the light on when your oil pressure is too low. Fix your leak and hope for the best.
    A quart of thicker oil is going to do sweet fuck all.
      Its a low/no pressure indicator only. I think its less than 5 psi or something. Thick oil does very little to slow down a leak. You'd do a lot better to plug the hole than to dump thicker oil in there.
        So if you have a cluster with the red engine light of death and a check oil light the engine light is for over heating and oil pressure less than 5 psi and you check oil light is basically a redundant light for oil pressure less than 5 psi? I wonder why they bothered adding the check oil light.
          The check oil light is for oil level, not pressure. Not all cars had it.
            I don't think I have either one on my '87!
            Nick
            Past: 1967 Continental convertible, 1987 TC Cartier, 1996 TC DAE & Signature, 2002 LS V8, 2006 Zephyr, 2010 MKZ AWD, and many more.....
            Current: 2010 F-150 Platinum Supercrew 4x4
            Wanted: 1967 or 1969 Contnential sedan
            Only in my dreams: A Continental Mark II
              You do have the oil pressure light. It's the general "oh shit" red light. Lights up for very low (your bearings are already fucked or the engine is at <300rpm or so) pressure, or for extreme overheating. Someone on here coined the "replace engine light" name because generally if it's hot enough or worn out enough for it to come on while the car is running you need a rebuild.
                You do. If its analog dash, both warning lamps are in the cluster of bulbs above the headlight switch. If its the digital, I think the low pressure light is built into the message center display. Not sure where the check oil is, maybe message center, maybe it's own lamp. Towncars did not have the red replace engine lamp though, or at least not the analog dash cars. They had a temperature gauge. The digital dash cars had an overheat indicator in the message center that was basically the replace engine lamp though.
                The check oil lamp comes on about 1 quart low. It should still have normal oil pressure with 1 quart missing. If you top it up when needed, you should never see the red light of doom from low oil. If its ignored, and you get to about 3 quarts low, it'll suck air and lose oil pressure. If both lights are on, basically its telling you that you're a moron for not checking the oil 2 quarts ago.
                  Interesting. I never knew that about the check oil light. I'm guessing there's a separate sensor for the oil level in cars that were equipped with that light in their dash?
                    Correct, it threads into a hole in the side of the oil pan.
                    I bought that type of oil pan planning to retrofit in a beeper or something hooked up to that sensor. Fox Mustangs used it as well.
                    | Junkyards
                      The low oil sensor is near where the dipstick goes into the block. If you find a wire sticking out of that side of the oil pan, thats what its for. Honestly, its among the better ideas for warning lights on cars if you ask me. Far more useful than a low washer fluid level indicator is.
                        I have both of those idiot lights on the 88... and I USE them.
