Hey,
I did the intake manifold and valve cover gaskets yesterday on the '83 (302, Motorcraft 2150 factory carb). While those missions seem to have been successful, in the process I discovered something I'm not familiar with. On the passenger side, running up over the valve covers there are two metal lines. Both are approximately the thickness of brake line, one may be a bit thicker.
One is fixed to the exhaust manifold, possibly with a flared threaded fitting (by feel since visually it's just a ton of rust) and connects directly to the underside of the choke thermostat.
The other is just dangling, but I found what feels like a broken off flared fitting further down on the exhaust manifold. The other end of it makes a 90-degree L on top of the valve cover and becomes a rubber line that goes to a nipple on the side of the thermactor valve on the passenger inner fender.
Can someone please explain the roles of these lines? I know carbureted thermactor systems are supposed to have a mechanism for killing the injection based on specific exhaust conditions (to prevent blasting fireballs through the cats I believe) and I'm wondering if that relates to the broken one.
