whats the best oil to use
    Moby, in theory they may be the same at operating temp, but there is something different enough between the two that when things get a little loose in the engine one gets consumed and the other not.
    Alex.
      I'm fixing to run 5W-30 in the Box to STAP and back. We'll see if it uses any. That engine uses NO oil when running 10W-30.
