Power Steering Pump Removal
    How do I remove the power steering pump pulley? I tried unbolting it, but the allen bolt wouldn't budge; regardless which direction I twisted it. Perhaps I missed something or it's siezed in there? I am replacing the power steering pump on the Ranger, which has the same set up as the CV. Thank You
    The power steering pump pulley is pressed on. You have to use a puller to get it off.
      Oh, okay. I guess a trip to the JY is in order. I will probably find another bracket and do all the necessary work beforehand. Thanks mcninetyone
