well, pump is coming out anyways. driving tonight, while i had a half full tank of gas, the "low fuel" warning came on. the needle then immediately dropped past "E" and sat there for about two minutes before coming back up to half and the low light went dark. happened twice more. safe bet is the sending unit.
the car feels like it has a slight miss above 35 mph while cruising, almost like a stumble. worse at higher speeds and worse while the A/C is running. we pulled some trouble codes at the shop and got the following;
(34) EVP – EGR did not respond properly during test – EVP
(18) Check base timing & advance function – Timing Tests
(14) Ignition pickup (PIP) was erratic – Ignition Systems
Overall I'm worried I have a myriad of issues of here and am beginning to regret my decision to buy this car. Its my 4th GMQ and I have never had the kinds of problems I am having here. Any input is welcome.
