Lugging along...transmission or?
    So, I finally got to take my '87 out of the garage and exercise it after it hibernated all winter. I was a gorgeous 80 degrees and sunny FINALLY, so I thought it proper to get it out of the garage. Car starts and runs well except for one issue. It seems that the transmission is "lugging". Even when coasting, with foot off the accelerator, I get this lugging sensation. At light throttle, O/D is kicking in around 38-39 mph. Anyways, shifting seems a bit unsure/confused. I had the intake off to clean things up over the winter and simply bolted the throttle cable assembly back onto the throttle body. I didn't make any adjustments to it before or after this event. Is it possible that this is now out of whack after unhooking and reinstalling it? I need to consult my shop manual as I have no idea how to adjust or to know what is correct. Fluid is clean and red, but I plan to change it anyways, for good measure. Any ideas?
    Nick
    it could have slipped a little during all of that. 1mm one way or the other will make a difference.
      Its possible. Does it not seem to want to downshift out of overdrive without a lot of throttle input? A cheater way to test if more pressure helps is to pull the cable end out a bit and put a zip tie between the "hat" crimped on the cable and the bit that goes into the throttle body. If that helps, you need a bit more. Or you can just rock the zip tie. I've had one on the Mark VII for probably 4 years now.
        'Lugging' is a good description of what I would occasionally experience in my Towncar....turned out to be carbon clogged EGR and passages.
          ^ don't be surprised about EGR. My 91 wagon lugs from carbon clogged EGR passages too
          -Nick M.
          Columbia, SC
            excellent points. The AOD is directly coupled in drive and overdrive, so any engine running problems will feel more obvious. Since it usually only shows up once it shifts, its easy to think its a transmission problem instead.
              Hmm, interesting fellas. I know what the EGR valve is, but how do I clean passages? Do I need to remove the intake again (crossing fingers the answer is no.)? The lugging only seems to occur when either maintaining speed with little to no throttle or decelerating. If I have moderate throttle going, accelerating or give 'er hell, she shifts through all the gears right nice with no bitching.
              Is it possible for the oxygen sensor(s) to be marginal without throwing a code? I would think I would have driveability problems throughout all conditions if these were the issue, though.
              Nick
                Did you unplug the EGR valve's regulator connector and go for a drive to see if the EGR is to blame? Leave everything else connected.
                I've had a bad plug wire cause symptoms similar to what you are describing.
                  Unplugged the EGR electrical connector and took her for a spin. Seemed maybe *slightly* better or it could have just been my imagination. How do I clean the channels? Do I just remove the valve? Plug wires are brand new Motorcrafts. I suppose I will have to check them out again just to confirm. It's weird that it only occurs while slightly decelerating or maintaining speed with no throttle action. Even slight throttle or half throttle or full throttle, I get none of the "hesitation" or "jerking". Engine doesn't change sound like it is being taxed or bogged down. Feels like a transmission issue very similar to one of my 96s that had a slight torque converter shudder or slippage.
                  Nick
                    Just to check - did you use dielectric grease in the plug wires in BOTH sides (plug AND Dizzy sides) before installation?
                      Yessiree Bob, I sure did! I thought maybe plug wires could be blamed in an opposite scenario when there is load being put on the engine.
                      Nick
                        I'm dealing with similar symptoms in the '91 and have been for most of the time I've had the car. I'm running out of parts to replace, so I'm watching this very closely, but won't hijack it for my own purposes. Just know you're not alone...
                        | Junkyards
                          I am going to give the zip tie a try when I have a few spare moments. Haven't done much high speed testing so I'm not sure what downshifting from O/D will be like. I will test that also. I do know that when either coming out of 4th or 3rd, decelerating of course, that it seems like the RPMs go down way farther than they should (like the downshift is delayed) and then the shift will occur and the RPMs elevate until I slow down more. Not sure what all this means. Have troubleshooting to do and fluid to change and see how it all turns out. Now to find a good thread on EGR cleaning....
                          Nick
                            Tried the ziptie trick. Didn't seem to make any difference. I am going to follow the manual on TV cable adjustment and make sure it is set in the right spot. I also ordered up an Innova code scanner with LED readout so that should be here tomorrow. I will see if I can get any codes to come back. Weird for a car with this mileage to have a problem like this.
                            Are the plug wires particularly sensitive to how they are oriented? I used the factory guides that were attached the valve cover bolts and the separators as original, but that's it. Didn't do anything special as far as routing goes. There's lots of places where the wires are very close or touching metal objects. I would think it would make no difference with a brand new set of wires. Any tips on things I should look out for?
                            Also, how do I clean the EGR valve and passages properly?
                            Nick
                              My car is doing the exact same thing (87 LTC base) let me know if you find anything. I could use the info!
                              Sent from my XT1031 using Tapatalk
