I decided to track down the coolant vapor smell I'm getting from under the hood of the 91 - I've got dribbles (under pressure) coming from behind the water pump, and some seepage from the t-stat gasket and all the hose clamps in that area. I'm going to replace just about everything, I just wanted to make sure I didn't buy a pump we are supposed to avoid!
water pump reccomendations
85HPP's most noteworthy mods: CFI to SEFI conversion w/HO upperstuff headers & flowmasters P71 airbox Towncar seats LED dash light-show center console w/5 gauge package LED 3rd brake light 3G alternator mini starter washer/coolant bottle upgrade Towncar power trunk pull underhood fuse/relay box 16" HPP wheels - police swaybars w/poly rubbers - budget Alpine driven 10 speaker stereoTags: None
I've changed mine a bunch of times, but I couldn't swear whats on there now. It may have come from Advance. Stay away from the reman pumps though, and make sure the bushing is in the fan clutch if its needed.86 Lincoln Town Car (Galactica).
the duracrap I got from AZ (not even the heavy duty pump... just the normal one) is still working like a champ on the 88 some 5 years later.
My auto zone duralast pump did pretty well for the few years i had it on. Gates makes good stuff, OEM for a lot of brands. That's what i have on there now-Phil
That's what I've been telling myself all this time... lol.
Alas, I saw definite dribbles coming from behind the backing plate.
Do we need to put thread sealer on any of the bolts? I thought that was just for Chevy's... but a co-worker asked if I put any on the bolts for the Bronco I just did... now I'm 2nd guessing myself!Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
make sure you put rtv on both sides of the backing plate gasket!
i like the duralast pumps also.
Originally posted by 85crownHPP View PostThat's what I've been telling myself all this time... lol.
Do we need to put thread sealer on any of the bolts? I thought that was just for Chevy's... but a co-worker asked if I put any on the bolts for the Bronco I just did... now I'm 2nd guessing myself!86 Lincoln Town Car (Galactica).
The parts are here... I went with a bosch regular-duty pump for 35 bucks. Rockauto had ALL the hoses on closeout too...
Does the backing plate only have two of its own bolts holding it on??? I thought I put a pump on the 85 and don't remember it being like that! but that's how the one on the 5.8 I just did was...
How does it not crush the gasket from having to tighten those two bolts up all the way first?? I wasn't as worried about it when I was putting one on someone else's vehicle... lol. ...no wonder they like to leak there...Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
for some reason I wanted to say it was 3 or 4 bolts holding the backing plate on, but they're all at the bottom. Maybe its only 2. Its very uneven and crappy, whatever the arrangement is.86 Lincoln Town Car (Galactica).
Just my .02, but since your taking everythign out I would probably change the timing cover gasket and timing chain"To Find yourself, you must first lose yourself"
-1973 Volkswagen Bus Westy
-1986 Honda Magna 700cc
-2011 Subaru Outback
Not a bad idea... I could make a good write-up too.
I wasn't planning on it since the 91 had the engine rebuilt in 2001 by the previous previous owner, but it's probably gotten 100,000 miles since then. I should check the receipt for the mileage...
My ultimate goal is to 'not have to go there' again, so maybe I'll go ahead. Of course I will if I snap any WP bolts off... lol.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
