Will a 351clev starter fit a 1991 302?
    Happy Saturday All,
    I have a Bosch starter (SR513X) for an automatic 351 Cleveland NIB and now have a need to replace the starter in the 91 GM with a stock302 FI.
    Before I get under the car, I was wondering if anyone knew if they would swap out? The GM is an automatic also.
    I do THANK YOU again,
    Mike
    90 Colony Park LS with GT 40 heads and intake. HO cam, 65 MM TB, 67 MM EGR spacer. Has a 75 MM Pro Flow mass air sensor. Borla XS mufflers. 3L55. Shift kit, 2000 stall Tq convertor...Bilstein shocks, front and rear sway bars.
    90 Colony Park LS 64,000 miles all original. 3L55 tow package....front and rear sway bars.
    91 Grand Marquis GS....HO motor..Bilstein shocks poly bushings and police swaybars. This one handles the best.
    70 Torino Squire with M code 351 Cleveland 3.00 has Magnaflow mufflers. Hidden headlights and power windows. All original
    Try doing a ROCKAUTO search and see if they fit both.
      I tried to use a starter from a 1974 Torino 302 on my wagon. It was physically bigger. I don't remember what exactly the problem was, but size was an issue. Maybe with the exhaust manifold.
      351C shares starters with the Windsor siblings.
        Even if it fits (and I don't know if it will) it's likely setup electrically the same way as the older boxes and may require moving a wire or two around to work on a 90-91 box. IIRC, the conversations that I have seen seemed to indicate that the wiring set up of the newer starter may be a better design, not to mention the newer starters are nicer because they deliver more torque but require les amperage from the battery and are quite a bit smaller/lighter.
        I know there are a few threads where guys have retro-fitted the newer starters on older boxes.
        Vic
