I worked on my colony park obsessively like 2 years ago, so now I'm a little fuzzier on the vacuum line plumbing.
I had the oddest squeaking, grinding noise that I would have sworn was a bearing or maybe a very strange belt squeal. It wasn't (checked with mechanic's stethoscope) and I was lost for ideas... but then at like the 4th shop I went to, the service writer walks right over, cracks the oil cap loose, and it goes away. ah HA that explains a couple things.
OK so what I understand is that the oil cap is on the valve cover, and the valve cover has a line that goes straight to the upper intake right? To engine vacuum.
Vacuum btw remains at healthy levels; I have a gauge I put in the dash a while ago.
So if it's making a whistling noise, it has to be sucking in (not blowing out)? As I write this I realize I could just put my hand over it or a sheet of paper then I'd know; but it's cold outside and my boots are off already
Which would also explain why the noise appears at idle and goes away when I step on the gas-- vacuum drops.
In conclusion it must just be a crappy seal on the oil cap, just the slightest break in that rubber ring on the underside and it's whistling through it like sucking air between your teeth? $5 from now I can fix this.
But someone suggested pcv valve... not sure that makes sense if the noise goes away when I crack the oil cap. Is there any other possibility than just the oil cap seal, or it has got to be just that?
