Code 34 Issue
    Code 34 Issue
    I have an issue with code 34 and code 31. I bought a scanner and it popped up so i went and bought a new one. Still comes up with the new one installed. 2 of the 3 bolts broke trying to take them out so i just have it held in with the one good one. I cleaned the EGR the other day and it didnt make a difference either. Any thoughts?
    2018 F150 XLT 43k
    1970 Buick GS 455 Stage 1 44k
    1968 Buick Riviera
    what did you try to replace exactly, the sensor? It won't work correctly without all of the bolts holding it in. Its a vacuum seal, and its probably leaking. Most likely you need a replacement EGR valve.
      The position sensor. If i need to drill out the old screws and put new ones in i will.
      2018 F150 XLT 43k
      1968 Buick Riviera
        I believe they are studs, not screws. If they're broken off, replacing the valve would be your best bet. There isn't really enough material to tap for a screw, and it wouldn't be airtight anyway.
          mine has bolts not studs. factory egr valve still.
          2018 F150 XLT 43k
          1968 Buick Riviera
            well if they are bolts and you can get them replaced, go for it. Either way, if the sensor doesn't sit in the right position and if it doesn't make a good seal, the valve won't open and/or the sensor will read wrong and give you stupid codes. Might be worth vacuum testing the valve to see if its any good before going to the bother of working on it. If you push the sensor in to make sure its sealed, and use a vacuum pump the valve should open and hold vacuum. if it doesn't, its done. The one on my Mark VII went leaky and gave me an intermittent check engine light. Never scanned it for codes, but replacing the valve with a good used one stopped the light.
              I never got a engine light from it but i plan on changing the egr valve out in the future. Nothing wrong with the motor in the car now but id rather have what it needs done fixed and have no issues before something major comes up from neglecting the parts which i try not to do.
              2018 F150 XLT 43k
              1968 Buick Riviera
                there is no check engine light for the computer on a 87
                  Ok so the engine light is just for when its dying and going to blow?
                  2018 F150 XLT 43k
                  1968 Buick Riviera
                    pretty much.
                      Ok so nothing to really worry about then. Ill just end up replacing the egr valve and i should be fine.
                      2018 F150 XLT 43k
                      1968 Buick Riviera
                        that's the general idea.
