Where can you run the wires from the oil and temp gauges throught the firewall easiest? im going to mount them down where the cigarette tray is
where to run temp and oil psi guage lines
are you using electric or mechanical guages?http://secondhandracing.com/Home.aspx
pretty sure they are mechanical, my temp gauge is just a coiled wire that goes into the lower intake where the old sensor was, and it lights up with power from the cigarette lighter.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Mine are run through a grommet thats right below the brake booster somewhere.86 Lincoln Town Car (Galactica).
