whats a good starter relay to buy?
starter relay
Do these go bad? Just kidding! I've used Motorcraft almost exclusively because my old friends still bill me out at "employee cash sale". I have used GP in a pinch (also two screwdrivers). As long as the relay winding says it's "diode protected" it should be okay.
They occasionally fail. If you start cooking them, replace the starter. Usually when the starter begins to die, it pulls too much current and frys the relay as a result.
If the push-on thing is broken, a ring terminal and a nut fixes it. I think thats an 8-32 or 10-32 stud.86 Lincoln Town Car (Galactica).
I like Standard, but they have started to sell two lines, one is cheap China made, would not buy those.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
