Ok so my '90 wagon is making a weird noise from under the hood. Sounds like you are shaking a spray paint can real fast. It makes it when:
You are cruising down the highway. Let off the throttle and it doesn't do it. Press the gas just a hair and it starts making noise. Press it just a little more and it goes away. Other then when the throttle is closed it only does it when you are cruising and at the top 1/4" of throttle. Past that it doesn't do it. I was thinking maybe valve train noise or something but I don't know...
