I figured you guys would like this as well.
Torque Specifications for Ford 5.0L-302ci-V8
Type: Bolt Dim: Length: Head: Hexagon Grade:
33 Ft-Lbs
396 In-Lbs
44.74 N-m
Connects: Bell Housing To Engine Block
Years: All Vote Record: Vote
Note:
Type: Dim: Length: Head: Grade:
22 Ft-Lbs
264 In-Lbs
29.83 N-m
Connects: Connecting Rod To Crankshaft
Note: Windsor - 5/16 in. Bolt on Cap (NOT Boss)
45 Ft-Lbs
540 In-Lbs
61.01 N-m
Years: 1969-1970 Vote Record: Vote
Note: Windsor Boss - 3/8 in. Bolt on Cap
65 Ft-Lbs
780 In-Lbs
88.13 N-m
Connects: Crankshaft To Engine Block
Years: - Vote Record: Vote
Note: Windsor - Step 22-44-65 (Boss - Inner Only)
40 Ft-Lbs
480 In-Lbs
54.23 N-m
Note: Windsor Boss - Outer Bolts on Cap
70 Ft-Lbs
840 In-Lbs
94.91 N-m
Connects: Cylinder Head To Engine Block
Note: Windsor - Step 45-55-70 Helical Sequence
80 Ft-Lbs
960 In-Lbs
108.47 N-m
Connects: Flywheel To Crankshaft
Note: Windsor
42 Ft-Lbs
504 In-Lbs
56.94 N-m
Connects: Fuel Pump Essentric To Timing Chain/Belt Sprocket
Note: Windsor
22 Ft-Lbs
264 In-Lbs
29.83 N-m
Connects: Intake Manifold To Cylinder Head
Years: All Vote Record: 3/4(75%)
Note: Windsor - Step 12-20-22
10 Ft-Lbs
120 In-Lbs
13.56 N-m
Connects: Oil Pan To Engine Block
Note: Windsor - 18Ft-Lbs @ Timing Cover & Rear Main
25 Ft-Lbs
300 In-Lbs
33.9 N-m
Connects: Oil Pump To Engine Block
Note: Windsor
35 Ft-Lbs
420 In-Lbs
47.45 N-m
Connects: Pressure Plate To Flywheel
Note: Windsor
20 Ft-Lbs
240 In-Lbs
27.12 N-m
Connects: Rocker Arm To Rocker Arm Stud
Note: Windsor Boss
70 Ft-Lbs
840 In-Lbs
94.91 N-m
Connects: Rocker Arm Stud To Cylinder Head
Note: Windsor Boss
13.5 Ft-Lbs
162 In-Lbs
18.3 N-m
Connects: Thermostat Housing To Intake Manifold
Note: Windsor
8 Ft-Lbs
96 In-Lbs
10.85 N-m
Connects: Thrust Plate To Engine Block
Note: Windsor - Red Loctite
13.5 Ft-Lbs
162 In-Lbs
18.3 N-m
Connects: Timing Chain/Belt Cover To Engine Block
Note: Windsor
42.5 Ft-Lbs
510 In-Lbs
57.62 N-m
Connects: Timing Chain/Belt Sprocket To Camshaft
Note: Windsor
4 Ft-Lbs
48 In-Lbs
5.42 N-m
Connects: Valve Cover To Cylinder Head
Note: Windsor
80 Ft-Lbs
960 In-Lbs
108.47 N-m
Connects: Vibration Damper/Hub To Crankshaft
Note: Windsor
13.5 Ft-Lbs
162 In-Lbs
18.3 N-m
Connects: Water Pump To Engine Block
Note: Windsor
33 Ft-Lbs
396 In-Lbs
44.74 N-m
Note:
22 Ft-Lbs
264 In-Lbs
29.83 N-m
45 Ft-Lbs
540 In-Lbs
61.01 N-m
65 Ft-Lbs
780 In-Lbs
88.13 N-m
40 Ft-Lbs
480 In-Lbs
54.23 N-m
70 Ft-Lbs
840 In-Lbs
94.91 N-m
80 Ft-Lbs
960 In-Lbs
108.47 N-m
Note: Windsor
42 Ft-Lbs
504 In-Lbs
56.94 N-m
Note: Windsor
22 Ft-Lbs
264 In-Lbs
29.83 N-m
10 Ft-Lbs
120 In-Lbs
13.56 N-m
25 Ft-Lbs
300 In-Lbs
33.9 N-m
Note: Windsor
35 Ft-Lbs
420 In-Lbs
47.45 N-m
Note: Windsor
20 Ft-Lbs
240 In-Lbs
27.12 N-m
Note: Windsor Boss
70 Ft-Lbs
840 In-Lbs
94.91 N-m
Note: Windsor Boss
13.5 Ft-Lbs
162 In-Lbs
18.3 N-m
Note: Windsor
8 Ft-Lbs
96 In-Lbs
10.85 N-m
13.5 Ft-Lbs
162 In-Lbs
18.3 N-m
Note: Windsor
42.5 Ft-Lbs
510 In-Lbs
57.62 N-m
Note: Windsor
4 Ft-Lbs
48 In-Lbs
5.42 N-m
Note: Windsor
80 Ft-Lbs
960 In-Lbs
108.47 N-m
Note: Windsor
13.5 Ft-Lbs
162 In-Lbs
18.3 N-m
Note: Windsor
