Info on 1984s
    Info on 1984s
    I'm contemplating buying a 84' townie with 20,000 miles.
    In the past, I've owned EEC-III cars which were an absolute nightmare. Could anyone fill me in on the troubles the 84' had? Was there anything specific to this year that's notable? Anything I should be looking for? Bear in mind, I've owned 20+ Panthers in my years....I just haven't owned anything with CFI, or whatever it had that year.
    Basically:
    Slow, difficult to make any faster without swapping the whole top end, very sensitive to vacuum leaks.
      Originally posted by johnunit View Post
      Basically:
      Slow I expected, LOL. My EEC-III cars just never ran right now matter what I fixed on them. Was this a carbed car? Fuel injected?
        Fuel injection in a carb body.
        My '84 Towncar runs fine with the CFI, starts up instantly, peppy and nice throttle response.
          when it works... it just works. when it doesn't... nightmare.
            84 is EEC IV, not EEC-III. Similar, but less expensive parts and easier to diagnose.
            It is otherwise a very smooth runner, but completely gutless. I think it made 140 hp or something. THey're miserly on fuel, particularly on the highway, but don't try to pass people. You might die. I would replace the timing chain as a preventative measure. Yes I realize its got 20k on it, but the cam gear has plastic teeth, and after 30 years in the oil the plastic is not as resiliant as it ought to be. It crumbles off and eventually enough comes off to let the chain hop. THese are interference engines and it will bend valves.
