Hello again, still trying to figure out the fuel related sometimes non start issue.
A few questions, sorry.
1. Where does the fuel pump wiring end up under the hood?
Seems like I touched a wiring harness under the intake and heard the fuel pump kick (hum) on with the key on.
I do not notice the fuel pump hum all of the time.
2. I just put on a new TPS last night and think I have much better gas mileage today.
What other sensors should I change out while I am at it?
3. I just got the IAC in today and will try to change it this weekend. It did not come with a gasket.
Will the local parts stores have a gasket? Should I use any gasket seal on it.
Actually that is all.
Thank you all,
Mike
Thank you all,
Mike
