fi the part is under warranty from the installer, you shouldn't have to pay anything to replace it again. Check your receipt to make sure though. some shops only do 60-90 day warranties.
90 Grand Marq won't start!
The relay is only a couple bucks, and its very possible the fuel pump or ECM relay could cause this. The ECM relay has to engage for the fuel pump to operate. Both of those sockets also can get crusty, so looking at the wiring is worth doing.86 Lincoln Town Car (Galactica).
I think you have plenty of evidence to support the fact that it is NOT the hose that I was talking about being split.
If it was that hose split the issue shouldn't be intermittent.
Also you mentioned that you did not hear the fuel pump when you last had this issue which points at relays, wiring, or connections like gadget mentioned.
If all the wiring, connections, and relays check out, then it could just be the fuel pump gone bad already like sly mentioned. As new as it is, it shouldn't be failing already but it is possible.Vic
I've had 2 fuel pump shut off issues in 'Stangs, I imagine the Panther cars have them also...
I've had issues with the fuel pump shut off switch on 2 'Stangs, I imagine the Panthers have tbem as well....
Originally posted by mitymerc View PostI've had issues with the fuel pump shut off switch on 2 'Stangs, I imagine the Panthers have tbem as well....Vic
Originally posted by VicCrownVic View PostThe switch in the trunk? (inertia switch I think it's called, I could be wrong on that)
I have seen intermittent pumps come out of the tank with the push-on terminal disconnected or poorly crimped before. That wouldn't be my first thing to look at, but its not impossible the wire is loose on the pump itself inside the tank.86 Lincoln Town Car (Galactica).
See this gets me wondering now because in the morning when it wouldn't start and after work when it stalled and wouldn't start I crawled down and felt the fuel pump housing and jiggled the wire connection around a little bit. I didn't think that my "wire jiggling" would have made a difference but both times it fired up right after. IDK, probably nothing.
I'm having trouble finding this fuel pump relay. I can't find anything in my ford manual about it, and my haynes manual is worthless. I'm guessing I need the electrical manual? I don't have one of those yet.
I disconnected the little plastic relay box on the inner driver side fender and pulled off the cover to find three equal and practically identical relays with no labels explaining which are which. Random person from an old thread posted that it was the one in the middle on his car so I said fuck it and replaced the one in the middle. Everything works... still don't know if thats the one though lol.
In the meantime I'll try cleaning out the IAC and see if that helps anything. weeee!
I was supposed to take a few in-state road trips recently but I'm a little too scared of experiencing that stomach dropping feeling of hearing your car cranking away without starting while hours away from home... we'll see.Last edited by BuffaloRider; 10-10-2013, 08:38 PM.
On my 91 the middle relay is the fuel pump relay, mine has the yellow labeling on the plastic casing.Vic
90/91 should have the same relay bank as the aeros. driver side fender up near the brake booster. The squarish black box with a small hang-on 3-relay box on it. should have the ECC, fuel pump, and AC-WOT cutout relays along with the ECC protection diode. IIRC, the fuel pump is the middle one.
