I’m having some trouble with my 5.0. It won’t start up right. I have to run the starter 3 to 8 times as long as I think I should. It also rumbles at idle. It seems to be misfiring when under stress when going 20-25 MPH in third gear, going up a hill. It behaves similarly when in Overdrive. I also notice it has a strange vibration in the top RPM range. The exhaust smells heavy. (maybe rich?) I can smell raw fuel at startup. I don’t see/feel any exhaust leaks however I smell fumes in the cabin. (Perhaps due to the heaviness of it)
I tried checking the coil impendence however my ohm meter is only accurate up to 0.02±. When I replaced the TFI module the engine died out at times. I then learned how to check for arcing. I noticed arcing on the coil itself. I also noticed arching at the output wire of the coil to some small wires near (I believe connected to) the coil. I replaced the coil. I replaced the wires with Ford racing wires. New cap and rotor. The spark plugs are relatively new Autollite platinums. With the new coil the new TFI module works just as well as the old one does. I have the TFI installed with nothing in-between it and the distributor. Made sure it was clean.
I just checked all of the plugs. They show that the engine is running hot. This could be because I recently used Lucas intake cleaner fuel additive the past 3 fill-ups. I also recently raced it 2 times recently. I have never been able to flush out all of the brown out of the coolant system. I flushed it maybe 4 times last summer using products. Now I’ve begun flushing it once daily.
Some other things that may be related: I’ve replaced the leaking steal fuel supply lines with rubber ones. New Fuel pump and filter. I replaced the PCV Valve. (it looked like it was done recently however it wasn’t sealed) New alternator I have reason to believe the voltage regulation circuit was going.
What I’m considering: The oxygen sensor on the driver side looks new. Looks can be deceiving. Is there one on the passenger side? I think it could be the TFI module because they both were used with the old coil. I feel it is the PIP sensor.
I would appreciate any advice I could get. Thank you in advance.
