I was able to locate a new IAC valve at last. Correct part number. Got it installed and started the car. Same problem still present, but runs for about 10 minutes before stalling. According to the mechanic the MAP sensor is working fine. What else should I look for?
Car stalling at first startup
basics, Fuel? Spark
Check for sparlk at the plugs.
For fuel, listen at rear of car have someone turn key to run (not start) do you hear fuel pump, sounds good?Last edited by jaywish; 07-11-2013, 06:26 AM.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
For fuel, listen at rear of car have someone turn key to run (not start) do you hear fuel pump, sounds good?sigpic1988 Colony Park
