hey guys... been a long time since I posted in here. Just wondering what the sensor is behind the grill infront of the rad and do I need it with my mass air the car has? assuming its for the motor input
sensor infront of rad? what the hell is it hmhm
Tags: None
The crash sensor? Or do you have auto climate control? If so it's the outside air temp. Neither are needed.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
thanks... never knew what that 1 sensor was for hmhm, I do have climate control yesFinally have an on the books porting/custom fab business!
if it's the metal box... that's a crash sensor. It activates the bomb.
somebody set up us the bomb!86 Lincoln Town Car (Galactica).
