Things to consider for a 5.0 engine rebuild/reman
    So the engine is in...and it is running pretty rough....the brain box...the Mark series ECM, does one have to tune or monkey with this?
    Is the firing order the same as the lo po?
    Is there a need to change the 02 sensors?
    (engine is 5.0 HO from a mark series)
    1979 Marquis creamy goodness
      an HO does not use the same firing order as a non-HO. It needs to be 1-3-7-2-6-5-4-8 for an HO engine.
      should not need any monkeybusiness to make a Mark VII ECM run on a basically stock HO. Thats what they run in a Mark VII.
      New oxygen sensors aren't a bad idea if they are old, but they don't do anything until the engine warms up over 120F or so.
        UPDATE.....SHIT. Car shakes. Red Engine Light goes on and off....engine runs ROUGH and then cuts off
        Confirmed the firing order is in....bad
        19lb injector?
        Have the right brain box in....my mechanic swears he hears a knock.....
        I got the cash....crate engine or reman?
          bad injector, bad wires, bad engine, huge intake leak, bad ignition module, timing WAY THE HELL out. Lots of stuff to check.
