I'm gearing towards doing a 351 in my town car. I found a 351 out of a Police Interceptor for $100. The engine supposedly is "tired". I'm leaning towards a roller block anyway, but what can I strip from it that is specific to the 351 swap in my 87 Town Car. From what I am aware i can use the oil pan/ pump/pickup and supposedly the a.c. bracket setup is required, and difficult to find. How bout the distributor? I want to make sure I don't waste my time and money, but by the same token I don't want to pass this + and wish I had bought it later.
86 CVPI 351 worth $100?
87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
Mods to come: Big Brake/Poly Front Swap, PI Front Swaybar, Addco 650 Rear Swaybar, Boxed Upper Rear Control Arms, 351/Alum Heads, FRPP Valve Covers,Tags: None
AC bracket is the only true hard to get part. I'd say buy it and take the AC bracket off and then re-sell the rest.
oil pan and AC bracket.... maybe the crank pulley. None of the top-end stuff is compatible with an EFI setup really. Block and heads were mediocre.
Ii could quite literally buy the motor, strip it, junk the block for $65, and sell the parts to someone who needs them on here.87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
there ya go.
100 bucks is cheap
Buy it for it's parts. The motor is not special but the AC bracket and oil pan are worth 100 bucks.86 Lincoln Town Car (Galactica).
