Was looking at Craigslist at work this morning and saw an 85 tbird with the 302 and they had a pic of the engine. Regular air cleaner like what was originally on my cfi motor but it has an EFI sticker on it. I've read the efi swap thread on here and I guess that's sefi? So how is 1985 efi set up? Is it like cfi but with mass air flow sensor instead of speed density?
Quick question
CFI is EFI, just a basic EFI. The S in SEFI stands for "sequential", which basically means that there's an injector for each cylinder times with the opening of the intake valve for that cylinder. Much more advanced and efficient. CFI is still Electronically controlled Fuel Injection, and Ford marketed it that way. The C stands for 'Central', as in the injectors aren't coordinated to the cylinders and are located before the air splits off to each cylinder.
CFI/EFI.. central fuel injection, 2 injectors on a carb controlled by the computer.
SEFI and up... injector for each cylinder controlled by the computer. basically the same idea you see now on cars just more advanced.
feel free to correct me if im wrong. im not TOO familiar with cars after the CFICharlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Alesha - Black 1982 Mercury Marquis - 255ci 178K, full custom Kenwood and Infinity system, lowered, dual exhaust, LED all the things
Tangerine Dream - Orange 1988 F-150 Custom - 300 i6 82k, Ghetto sound system, 5spd, 2WD, #farmtruck
Originally posted by johnunit View PostCFI is EFI, just a basic EFI. The S in SEFI stands for "sequential", which basically means that there's an injector for each cylinder times with the opening of the intake valve for that cylinder. Much more advanced and efficient. CFI is still Electronically controlled Fuel Injection, and Ford marketed it that way. The C stands for 'Central', as in the injectors aren't coordinated to the cylinders and are located before the air splits off to each cylinder.sigpic
GrandestMarquis
Both of those are EFI. Anything without a carb is EFI. There are three types of EFI- Central, Sequential and now Direct where the injector dumps directly into the combustion chamber as opposed to the manifold. Any other types I missed?Last edited by jaywish; 06-05-2013, 02:00 PM.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
In panthers, SEFI was available in MAF and Speed. Not sure about CFI but since it was older tech I would guess speed.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
yeah nothing with the carburetor-type air filter is MAF.
Originally posted by jaywish View PostBoth of those are EFI. Anything without a carb is EFI. There are three types of EFI- Central, Sequential and now Direct where the injector dumps directly into the combustion chamber as opposed to the manifold. Any other types I missed?
The mass air thing isn't really dependant on what sort of system you ran. The SEFI in the non-Mustang cars were almost all speed-density, which does not use a mass air sensor. Some of the trucks had a MAF, but I think that started in 94 or something. 91 California Vics were mass air, but none of the others were. I don't know of anyone who ran mass air with a throttle body type system, but its not impossible that it exists.Last edited by gadget73; 06-05-2013, 05:58 PM.86 Lincoln Town Car (Galactica).
