Getting ready to do the timing chain and gears on stock 1983 GM. Gonna get the Comp Cams timing set from summit. My question is, on the bone stock motor, can I advance the cam timing the 4 degrees that the new cam gear allows?
Will valve to piston clearance be an issue and will cfi accept it?
