Box Exhaust Question
    Does anyone know if you can install the dual tailpipes and mufflers from an Aero into a Box that has duals without modifications other than, of course, modifying the hangers? Basically, my question is: will the Aero mufflers/tailpipes line up with the Box H-pipe, and will they fit over the Box rear axle, etc. I realize that they might (??) be different diameters, but that can be easily dealt with. Thanks for your help.
    I've never done it, but I really can't see why not. I think the diameter is the same as well, but I stand to be corrected on that.
      from the cat-back I think they're similar. The aero is 2.25 while the box is 2. you may have to adapt the pipes. The best way would probably be to cut the Y pipe before the bends and leave that on the cats and then mate the H pipe up to that. The downpipes are way different.
        It would be a great way to pick up a stainless exhaust if it can be made to work simply.
