Hey guys. Put a motor in the Merc (89 GM/5.0) over the summer. I put a new Dormans oil pan on it, before I dropped it in. The drain plugs supplied with the pan leak. Fortunately, I found the perfect replacements for the Dorman plugs. FORD part #F75Z-6730-BA. These are for the V-8/V-10 Triton motors. They are a direct fit, with built in gaskets. We stock these at my job, as they are made to strip out if they are tightened too tightly so that you don't wreck the oil pan. Just an FYI for anyone wanting to use the Dorman pan. I have no complaints about it, otherwise.
MIKE
MIKE
